OT: exporting video for DVD http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=5762 |
Author: | James Orr [ Tue Mar 21, 2006 10:34 am ] |
Post subject: | |
This is off topic but I thought I'd just see. I'm not a video guy, but I'm ready to export some things for DVD Studio Pro from Final Cut HD. Has anyone else done this? I'm just wondering what you like for your export settings. |
Author: | John Mayes [ Tue Mar 21, 2006 1:44 pm ] |
Post subject: | |
James, Been there done that a dozen times at least! I'd use compressor and set it to the appropriate length choice. Say for instance your video is 90 minutes long I'd choose DVD 90 minute best quality .. 4:3 (or 16:9 if that is what ya want). The best quality is important because it uses a 2 pass VBR which is essential for good motion. Then in your inspector window click the quality tab and then you can either just go with the std. choices which are great, or if your pressed for disc space you can bump the average bit rate down to NO LOWER than 3.0 Mbps. Also for the audio I normally use Aiff, but if your pressed for space Dolby uses considerably less disc space. Hope that helps! |
Author: | James Orr [ Wed Mar 22, 2006 5:10 am ] |
Post subject: | |
Awesome. Thanks John, I was hoping you'd see this. I'm so much more confortable with actionscript :) |
